Hi folks,
Can someone explain to me how Silent Mode works in Arlo Doorbell? I turned it on, then two more settings showed up underneath - Incoming Call & Chime. At the moment, both new settings are turned off. If I turn them on, does this mean, incoming calls will go through or not? The same with chime, if turned on, will it turn it on or off? So confusing since it does not confirm that it's on or off. How about adding a text below indicating incoming calls are turned off or chimes are turned off?
Your assumptions are all correct. Enabling silent mode allows you to choose what is silent - one or both.
