Doorbell will not sync
Doorbell won’t sync? Why not? Light flashes but says can’t find it?
5 REPLIES 5
Yes. Still won’t sync to my account or phone. My cameras did perfectly and easily.
Have you tried to reset it by holding down the reset button for 10 seconds? The button is located between the batteries. I have provided an article with further information: How do I reset my Arlo Audio Doorbell?
Yes I have. Still won’t sync. Can I send back and get a replacement?
I would suggest contacting support regarding your doorbell. I have attached the link for you Arlo Tech Support
