  • 6 Replies
  • 3577 Views
  • 3 Likes
  • 5 In Conversation
pat5150
The button has no feel.  It's really stiff and takes a firm push to activate my traditional chime.  Is mine defective, or are they all like that?
6 REPLIES 6
skingspan
Luminary
Luminary
I purchased two doobells and they are both like that.  They give the user no feedback so it is difficult to know if the doorbell press was sucessfull.  Major flaw in my opinion.
https://wickedsmarthome.blogspot.com/
Andyzzzz
Yes I agree. No finger feedback / audio feedback when pressed. Would suggest they use the speaker to play a noise so you know it has been pressed.
motokochan
The button is kinda like the newer Apple keyboards. There's very little travel on it. You can feel the "click" if you're attentive, but it's really subtle.
pat5150
Seems to be the design.  No "finger-feedback" I like that. I appreciate the responses and agree it's a design flaw for sure.
RChobby
Virtuoso
Virtuoso
The doorbell button press does not give the visitor any feedback for a successful press. Can this eventually be programmed in?
skingspan
Luminary
Luminary
I would think that since the doorbell has a speaker built in they could have the doorbell itself play a chime when pressed.   Just a software change so shouldn't be too big a change.
  • 6 Replies
  • 3578 Views
  • 3 Likes
  • 5 In Conversation
