Door bell no longer calls after ringing, motion sensor not triggering
FIrst problem:
After one day of working, when you ring the doorbell it no longer calls anyone.
Also, the motion sensor no longer seems to trigger.
As of right now is a fancy looking button that rings my doorbell -_-
Second problem:
Even when it did call someone, it would only call me. My wife has the arlo app and has grant access and she does not get the calls.
Third problem: Why was this not released with out of the box Alexa support? It would have been a no brainer to have this call Echo Show directly and answer door call there. When is this coming?
Thank you
Be sure your wife has the very latest arlo app on her phone.
Also:
In your Grant Access settings for the primary account, do you have the doorbell shared with the other users?
Not at first, we realized later it was off. By the time we turned it on though, the Arlo stopped calling anyone altogether as stated on my first complaint
darkleafar,
Which mobile app are you using (iOS/Android)? What happens when the doorbell button is press (LED behavior)?
Are you logged in and is the mobile app running on your mobile device?
I'm facing the second issue as well. I have Arlo Doorbell set up and working properly on my account. I've granted access to the devices on my base station (including the doorbell) with my wife who has a separate account. The doorbell will ring my phone/app, but not hers no matter what I do.
I too am having issues with it not calling consistently. The initial setup went smoothly and the few tests worked perfectly. Then the next few days have not called when people ring the doorbell. I’m seriously thinking about returning it. I’m going to try troubleshooting more.
Unfortunately, Android's recent baterry-saving strategy causes apps to not get notification (or calls in this case) becuase the app is forced to sleep. I've set mine to not be optimized for battery life with little to no effect. If the phone has been awakened recently or is currently awake, the call comes through. Tough nut to crack and Arlo isn't the only one to have this problem.
I solved the issue by deleting the doorbell, doing a factory reset, and reattaching it. Let's see how long it lasts...
I also did a factory reset and it seems to work, although now my wife's app keeps crashing (iPhone X). It won't stay open.
You can Factory reset by holding down the sync button between the batteries (while it's on) for 10 seconds. Hold it until you see the light ring flicker definitively. If it doesn't do that, it hasn't reset. Took me an hour to figure that out yesterday.
It works sporadically. We have tested it a few times throughout the day after the reset and it its IFFY at best.
Im afraid I have adopted this product far too early. You guys released some half baked ass stuff
I find that recent OSes use battery saving strategies that cause this to happen. Even setting Android to not optimize the Arlo app for battery savings I still don't get calls/notifications right away is the phone has been asleep. That's an OS issue, not Arlo. Other apps have the same problem.
If ths phone is awake or has recently been so the calls come through properly.
I’m on Apple IOS. What’s everyone else using? OS roll call......
I attempted the same, but now my system is refusing to FIND my doorbell to re-connect. Sheesh... what a mess.
Did you try deleting and adding the doorbell back to the base station?
Make sure that it is removed from the base when doing this. You may also have to hold in the SYNC button between the batteries for a few seconds until the LED ring flashed quickly.
Holding the sync button on this thing forever and not seeing the 'definitive light flickering' you mentioned. I don't know if any aspect of this product was quality controlled. Sheesh...
They recommend 10 seconds to reset the doorbell.
You might want to try restarting the base station as well.
Update after about 3 days: I did eventually get things to reset. I was having issues with my wife's iPhone X crashing every time we opened the app. So I was moving devices between our two basic accounts and noticed that the cameras and doorbell in general sometimes struggle to "reset". You have to really hold that button for a while. 10-15 seconds.
But once I did that, it has been working reliably for me for the last several days.
One tip - If you have granted access rights to someone else (spouse, etc) and their app keeps crashing, it's likely due to the two accounts each sharing cameras. My wife's did it in two different accounts, but once I removed all devices from her account and put them all in mine, then granted her access - her app has been fine.
And we're both getting notifications when someone rings the doorbell.
