Arlo Doorbell will not recognize my phone. Someone else initially set up my system. Need new admin
Unfortunately that did not work after multiple attempts. I ended up having to do a re-set and then immediately after that a sync with my phone. The sequence was 10 sec reset/sync on the doorbell, then another 3 sec reset/sync then a 3 sec hold of the sync button on the top of the base. I had to do this with the chime as well. Easy enough once customer service explained that to me but nowhere online or in any of the literature is this explained. The customer service guy was very helpful but it does make me wonder if they are just giving you enough info to get by but if you have any questions after 90 days, you have to pay for help.
AT this time, there's no cost for support regardless of what the documentation says. Whether that remains in the future is unknown but folks are using free support even after the warranty period is up. The docs are seemingly a hold-over from the Netgear days where the networking devices have this issue.
