Do I need a base station with the Audio Doorbell/Chime
I already have a camera security system (not through Arlo). So I don't want a video doorbell.
If I get the Arlo Audio, can I use my own chime?
Do I need a base station, if the arlo audio and arlo audio doorbell will be standalone devices?
What are the minimum devices I need? An Arlo Audio Doorbell, and Arlo Chime?
Is the Base Station required to work with Alexa? That is not important to me.
Hi @nuraman00
Q. What are the minimum devices I need? An Arlo Audio Doorbell, and Arlo Chime?
- A. You will need a SmartHub or Base Station to utilize an Arlo audio doorbell or chime.
Q. If I get the Arlo Audio, can I use my own chime?
- A. You can connect your Arlo Audio Doorbell to mechanical or electronic doorbells if they operate at a voltage between 8 and 24 volts AC. You can find more info here: How do I set up my Arlo Audio Doorbell to trigger my existing chime?
Can I use my own mp3 chime, and configure that?
Also, can I connect one Arlo Audio Doorbell to multiple Arlo Chimes?
I want to spread out the Chimes throughout the house, to different areas.
You will not be able to use your own mp3 chime. You can use two audio doorbells & 5 chimes with a Base Station or SmartHub.
