Chime audio is bad - crackling and popping
I'm getting garbled audio with the Chime when the doorbell is rung or when I'm testing melodies. It cracks and pops and doesn't sound smooth. I've tried three different outlets and all have the same issue. I've also tried different volume levels but with no luck.
Any idea what I can do to fix this? Is this a software issue or does it sound like a bad unit?
bborisbb,
How far away from the base station is the Arlo Chime? If you move it closer, do you still experience the same results?
It was one floor up from the hub. I tried moving it to the same room as the hub but it was exhibiting the same problem.
bborisbb,
I will reach out to you in a private message to gather more information on this topic.
Please help me resolve the bad audio - crackling and popping.
