Can I use Alexa INSTEAD of Arlo base station?
I bought Arlo Audio Doorbell, but I dont have Arlo-base station. Can I use Alexa INSTEAD of Arlo base station?
The audio doorbell requires a base. There is a wireless video doorbell that can be connected to your home wifi.
Alexa provides a control point for your devices, but it doesn't actually connect your devices to the internet.
I totally gave up trying to get Arlo BabyCam's to work with Alexa, the support was so variable. it seems to be dependant on some external server performance vs just a local connection. Good luck.
