  • 6 Replies
  • 8920 Views
  • 3 Likes
gildrush
The Doorbell has suddenly stopped detecting motion. A short time ago a press on the Doorbell would not ring the chime. Tried all known methods to re-sync before it started to work. Then I recently noticed the Doorbell not detecting any motion unless I press the button. Did a 10 sec reset that did nothing. This whole Doorbell setup is very unstable now. It worked fine for sometime when first setup. I'm at a loss.
6 REPLIES 6
qureshibe
Disarmed Mode - Same here no longer motion detection trigger.
When standing in front but not pressed, It shows flashing white light while motioning around.
When pressed, It rings chime & triggers recording
When pressed, It calls on phones & triggers recording
I thought of customizing a RULE, but rules only available for CAMS, not for the doorbell
I have ARLO ULTRA
brh
@qureshibe,
I also can not get my doorbell to record videos and send notifications with the Ultra cameras but it does work well with all the previous models.
Now, as for the second part of your statement, on the devices page, click on the doorbell. Click on the three dots at the upper right of the page. On the next page you will see a section for Motion Settings. Click on that and you will be able to setup the rules for the doorbell.
I have reported this issue, but no resolution yet.
Brian
qureshibe
2nd part also doesn't work.
I have tried setting up a rule for 1 cam for 2 cams with doorbell motion trigger, but no change.
It doesn't do the recording.
detections are visible but recordings are not getting on,
for example last night when I was going out, doorbell detected me & activated the Ultra Cam spotlight, then again no recording
brh
@qureshibe,
Mine have never worked with the Ultra cameras. I was told this was a known issue and I am waiting for a resolution. Meanwhile, especially if it worked before, you might want to contact Customer Support at:
Brian
qureshibe
Opened a case with support.
gildrush
Well now my Doorbell is "Dead as a doorbell". Fresh batteries, tried sync button and no response to anything. Warranty is expired so now what?
  • 6 Replies
  • 8921 Views
  • 3 Likes
