  • 2 Replies
  • 1256 Views
Jb74
Looks like the wiring from existing chime has to feed from behind the back plate. My existing wiring comes from the left of the door frame so would stop the backplate from sitting flush. Is there a way around this even if it means cutting a bit of the back plate to allow the plate to fit over the wires?
JessicaP
Hi @Jb74,
Could you provide a picture of the problem you're describing?
schumaku
There is no prepared section to cut-out a surface mounted cable - sections of the base plate should allow optional cut-out (on all four sides, top, down, left, right ...) to allow an existing surface mounted cable to reach the contacts, still allowing to have the base mounted flush.
Please click on thumbs up if this answer was useful - thank you!
  • 2 Replies
  • 1257 Views
