Arlo Chimes only one sync can't get second one to sync
  • 1564 Views
GPast1
I bought 2 arlo chimes for my 2 story house. Only one will work with doorbell at one time. How can I get both to work?
JessicaP
Hi @GPast1,
Just to make sure, have you added both Arlo Chimes to your device? Make sure that the Arlo Chimes are set up close to the Base Station and then move it to see if it works.
GPast1
I have 2 arlo chimes hooked up to the doorbell. Why does only one will work when the call received button is choosen?
JessicaP
Try to remove the Arlo Chime that is not working and re-add it back on to see if that helps with both Arlo Chimes working.
  • 1565 Views
