In the Arlo Audio Doorbell mobile app, what is the meaning of the Device Setting "Call Setting" "Mute"?
What does it control?
What happen when it is ON? OFF?
It determines whether the phone mic is muted when getting a call. Not sure why muted is the default.
(See attached mobile screenshot)
In the Arlo Audio Doorbell Mobile App, what is the meaning of the Device Setting "Call Setting" "Mute"?
Apparently the Device Setting "Call Setting" "Mute" is NOT shown on the myArlo webpage, and I don't know why.
Thanks for the help
The mic on/off turns off the mic of the phone so the door bell does not pick up phone input... I usu leave the mic off.
Same thing, diff wording between app and web
Play with it, you can't hurt anything
Anyone else have this problem. I’ve toggled the darn switch on/off, reset the app, re-downloaded the app and rebooted the phone. Nothing seems to work and I absolutely need that setting to stick! Any other ideas?
In my understanding, this does reflect the default settings when accepting a Audio Doorbell call on the mobile.
Here on App v2.6.5_23400 (Pixel 2 Android 9 or Nexus 6P Android 8.1), I don't see the mute indicator is set according to the preset "Mute on".
However, if the settings has mute on, we have to touch the mute button twice before the audio from the phone to Doorbell will become available (by far not loud enough, but that's another issue).
Please click on thumbs up if this answer was useful - thank you!
Doesn’t seem to work on my or my wife’s iPhone XS running latest OS and firmware. Have sent to mute but mute is not on when answering doorbell call.
Hi @Abmet,
Is the issue happening when you're on both the main account and shared (grant access) account on your iPhone XS? Have you tried to reinstall the app to see if that helps?
Both phones are iPhone XS on iOS 12.1.2.
Have you tried to remove the granted account & re add it?
I can certainly try again tonight.
@QuintusPre did that work for you?
Tried it again and shared access account does not respect the “mute” setting. Had to revert logging into the main account.
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
I will wait for the issue to be resolved in a software update as I’m content with my current workaround.
