  • 2 Replies
  • 2959 Views
Ted4321
I have successfully connected two (2) audio doorbells to a VMB-4000 base, for the front and back door.
No pairing to any cameras. Primary use for doorbell press only and motion sensing to alert chime.
One of them keeps disconnecting after a few days.
Stats:
Base Station -> VMB-4000 works flawlessly with multiple cams and one digital chime
Chime -> 1st gen digital chime (no problems or connection issues)
AAD1001 (Front) -> using switch #2 (no problems, switch unchanged remains at #2)
AAD1001 (Back) -> have unsuccessfully tried switch # 1,2,3 with the same disconnection issue after ~48 hrs.
Suggestions?
Ted4321
SOLVED: The AA batteries were making an intermittent connection. Rotated the batteries and all seems fine.
Suggestions?
I don't think I can help (been a long time since I used the AAD1001).  But I think would good if you can tell us if both doorbells are connected to the same chime.
Though it's a bit of a pain, you could try swapping the doorbells and see if the problem moves.
Ted4321
  • 2 Replies
  • 2960 Views
