I'm trying to build an automated home (so far I have independant but wireless Arlo Pro cameras and base station, wireless garage doors, and wireless thermostat, will add light sockets, motion sensors, water sensors through Samsung SmartThings and also an Amazon Echo for voice control). Over in the SmartThings forum, it appears ArloPro integration is broken. Is the support just a bug, or is there no partnership here?
Thanks, just want to know what is directly compatible with the Arlo Pros, and what can be integrated through third party like SmartThings.
John
Funnily enough, a few hours ago, I received an email from smartthings saying April updates bring compatibility with Arlo Pro, Arlo Pro basestation, Arlo Q and Arlo Q Plus. I guess they weren't properly integrated previously. You might need to remove them from your ST and re-add them to get the full functionality
What's the problem? I also have Arlo cams x5, garage door opener, hue lights, ST motion sensors, and 3x Echo Dots.
I use Arlo independently but it is linked through ST. My cameras set off inside/outside lights at certain times of the day through ST. Other than that, I run my arlo on a schedule and not in Smartthings mode
As I understand it, SmartThings suddenly stopped communicating with the cameras properly over the last couple of days. Not sure of the details, I saw this on the SmartThings forum as I was researching the ability to integrate all my wireless devices...
Yep, that appears to be it! Thanks.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
