"linking your Arlo account", there after i get an error message "could not reach arlo, please try ag
  • 5 Replies
  • 4549 Views
Justmithun
I recently acquired a Google home hub, and I have an Arlo pro 2 base station and camera setup and in use for a few years.
When I try to link the Arlo to my Google home hub, i am prompted to authenticate my Arlo credentials, and when I proceed with it, i get a message "linking your Arlo account", there after i get an error message "could not reach arlo, please try again".
I have removed and readded both the base station and camera, with the same results.
I saw some article suggesting trying to sync from Google assistant, I tried that and still the same result.
My Arlo camera and base station are connected to the same wifi network and so is the Google home hub.
Any suggestions or solutions will be helpful.
5 REPLIES 5
Justmithun
How long does it usually take to get a response from the support team?
Also, I saw some articles regarding token reset, would that be applicable in this case as well?
This is a user-user forum, so you aren't communicating with support here.
I'm tagging the mods, in case they can help:  @JamesC , @ShayneS
No, that's only for Apple Homekit.
Justmithun
Thank you Stephen, appreciate your response and thank you for tagging the mods.
I understand it's not support per se, but there are ppl from Arlo that do respond, so was hoping I get a response or a solution from them.
Justmithun,
You mention following the instructions in an article, are you referring to this one? https://kb.arlo.com/000055108/How-do-I-connect-my-Arlo-devices-to-Google-Home-or-Google-Assistant
Make sure your mobile device is connected to the same network as the Google hub and the Arlo system when going through setup. At what point during the above process do you experiencing an issue?
Justmithun
Hi James,
First of all, thank you for your response.
To answer your question, the linking fails after Arlo credentials are verified. It accepts the credentials, since i am already signed into arlo on the device i am using. It then States linking to your Arlo account, then I get the message, could not reach Arlo, please try again.
Please note all devices are connected to the same wifi network.
