Wmb4540, Smartthings app
  • 1 Reply
  • 1719 Views
Stoolpe
I want to integrate WMB4540, Arlo pro 3 cameras with Smartthings.
When I had Arlo Premium it worked fine, it was recording when the doorsensor was triggerd and so on.
But now when I don't have Premium anymore I save my videos to local usb and that doesn't work.
It works if I don't use the Smartthings app, only Arlo app, but then I can't use my doors doorsensor.
Please help.
dcfox1
For the Pro3 I believe you need cloud recordings to see recordings in the Smartthings app as it can't connect to the Hub.  Just the Arlo app as you said. It has been a while since I used it so someone correct me if I am wrong.
