HomeKit Arlo Video Doorbell Sound issue
Sound works fine in the Arlo app for cellular and wifi.
HI @Jeffwc
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Hi @Jeffwc ,
Just to make certain of what I think is going on, I have an additional question for you: Does the issue occur when you are on a Wi-Fi network besides your own? If yes, then I think I might know the source of the issue.
A lot of the time with one-way audio, the issue is specific to a setting called "SIP ALG", which is a feature of many routers to fix the IP address on SIP Calls (voice/video calls over the internet). The feature is used to make sure the IP Address is directed to the correct place, but sometimes can break SIP calls. What I recommend is checking your router settings to see if SIP ALG is there. If it is and enabled, try disabling it and trying again. If it is disabled, enable it and try again.
If you aren't sure whether your router has the feature, let us know what model router you have. And let us know whether the SIP ALG setting might fix the issue for you. If not, we will follow up for more troubleshooting.
Thank you,
Mark V
L3 Tech
Thanks!
Hi @Ramses10
Are you still experiencing this issue with incoming audio when on mobile data through HomeKit?
Hello everyone,
I wanted to clarify if you are all running the latest version of the following on your devices.
- Video Doorbell Firmware: AVD1001 - 1.14.0.0_931_5ed3664_1c4138d
- iOS version 14.4.2
- iOS Arlo Mobile App v3.1
Hello,
This issue is on Apple's side. I will provide an update when Apple fixes the issue.
Thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
