- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB5000 -- HomeKit stuck at "Connecting to Bri...
I'm trying to connect my Arlo cameras to HomeKit and the process fails at the "Connecting to Bridge" step. I'm adding through the Arlo app, not through the Apple Home app.
Steps:
- Base Station device settings >
- [HomeKit] >
- "Discovering your device. Please wait" > [Basestation XYZ] SUCCESS
- "Select a Home" > [My Home]
- "Select a Room" > [Default Room]
- "Requesting HomeKit info..." SUCCESS
- "Locate the QR code" > [Continue]
- "Add Accessory" > scan QR code >
- "Connecting to Bridge" HANGS
I'm trying to connect to a new Apple HomePod Mini (running iOS 15.0).
VMB5000 Base Station and all cameras are running latest firmware.
I'm using the latest version of the Arlo app (3.5.6)
iPhone 11 Pro Max running iOS 15.0.2
I've rebooted all devices multiple times (Base Station, cameras, HomePod, iPhone). I've removed and re-added the Base Station multiple times. I've tried the HomePod in various locations around the house, including right next to the Base Station. Frustrating as I went with Arlo on the basis of the integration with HomeKit.
I have reset your HomeKit tokens, Please reboot your base station and try again.
Thank You
Having the exact same issue. Going through steps, "Connecting to Bridge" and it hangs. On latest firmware.
When trying to connect through the Home app and adding accessory I get it is an uncertified accessory.
Help!
Thank You
Thanks! It's working now
Done all the same things.
Stuck at connecting to bridge
Having the exact same issues as the previous replies.
I have reset 2/3 of your devices, if you can bring your Smart Hub back online I will reset the HomeKit token for this as well.
Could I get a reset ? For some reason it wouldn’t work on homekit when away from home network, so redoing homekit and stuck in discovering
Hi, my smart hub also seems to be having the same issue with being stuck on connecting when trying to connect it to homekit. Can you help?
I too have this issue of adding to HomeKit hangs, please reset.
Wow I have this same problem, seems to be a ton of threads on this. Brand new out of box, can't connect to homekit. :(. I guess can I get a reset too? This really sounds like an issue that needs a software fix instead of folks having to do this over and over, no?
Upgraded from vmb4500 to 5000.
Disconnected the old one and ran all the upgrades, still no luck. This might do the trick.
Best rgrs.
Hi, same problem here, stuck on ‘connecting to the bridge. Can you please reset the tokens? Thanks, Gunther
It's the same thing with me. I am trying to connect it through the Arlo app but it hangs.
Tried resetting the base station, but nothing. Not sure if there is any other step I am missing.
I have this same problem. I have another VMB4000 smart hub that I have removed from HomeKit, but still getting this issue.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
