- English
- Arlo Forum Discussions
- Partner Integrations
- Re: VMB4000r3 token reset needed for Apple HomeKit
noticed several previous reset request, pretty sure what i need
i have 2 base station, newer station 4500 all OK with Apple HomeKit.
but VMB4000r3 not responding , firmware is latest per app, SN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions
:How do I connect my Arlo device to Apple HomeKit?
I am also trying to reconnect my VMB4000r3 to Homekit and probably need a token reset.
I seen the DM you had sent me and responded to that. Let me know if there is any questions.
Thanks. HomeKit worked for about a week. Now the base unit shows offline. I’ve tried resets, cord swaps and plugging it directly to the router with no change. I switched the cameras to WiFi so I’d at least have function but that doesn’t work with HomeKit…
I need a token too for both of my base stations. Appreciate if a mid can send them.
I've just changed my mesh network hardware & created a new WLAN, now I can't get Arlo working on Apple Home any more. Can I get a token reset as well please?
Model: VMB4540r2
Serial ending in 0192
@joenkim I am unable to reset the token as the basestation is offline.
@WombatFirst I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
@Courty I replied to the dm you sent me.
Yes, that is my current issue. It will not connect.
Have you tried to reset the basestation and add it back onto the account?
I’ve reset it by unplugging it for 30 seconds, changed the cable, and plugged it in to different ports. The center light remains orange.
I also need a token reset - can you please provide?
Thanks the token reset works perfect.
Suspect I need the same token reset, as I'm unable to add my VMB4000R3 to homekit.
SN 4RD3837VA1EDE
Hi, thanks for the update. Unfortunately, I still don't see the Homekit option.
Have tried unplugging the base station, and restarting it, yet in the app when I go to Devices and choose the base station, I see Device Settings, Video Settings, Storage Settings, Support and Paired Devices. Nothing about Homekit.
Hi BrookeN, that has helped somewhat, as the Homekit option has appeared in Base Station settings, however I'm now stuck at the next step, where it remains frozen on "Discovering your device. Please wait."
Any suggestions?
Try logging out and logging back in and then follow the instructions to set up without a code.
I need a token reset as well please. My VMB4000r3 does not show up when following directions for HomeKit setup
AppleTV
Samsung SmartThings
80 -
Security System
