VMB4000r3 Homekit
  • 9 Replies
  • 9859 Views
  • 5 In Conversation
SeymourS
Hi,
I'm getting an error when trying to connect my base (VMB4000r3) to Apple Homekit. I've read in the Arlo community that this was solved with a "token reset". How can I make this request or is a community mod able to help me with this?
ShayneS
Thank you
9 REPLIES 9
ShayneS
Thank you
SeymourS
Thank you. That made it work immediately.
Gsjtjdicndak
I have the same issue with a VMB4000r3 base station.  Could you please reset my token as well?
SN 4R036C7HA20B0
Gsjtjdicndak,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
martin8888
Hi there. I think I have the same issue. HomeKit doesn’t appear as an option on my app for my basestation vmb4000r3
can you reset it please?
martin8888
Thank you. I’ve restarted it several times but the HomeKit option still doesn’t appear within the app?
martin8888,
If you're still experiencing an issue, you may need to factory reset and re-onboard your base station. Afterward, I can send another token reset and you can test  to see if that works.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
Gsjtjdicndak
This was successful, thank you JamesC... although I got a warning from Apple that my base station is not Homekit certified and I was disappointed that iCloud+ video saves and history are not supported.  This would give me some comfort as Arlo EOL's various devices.
