I can not connect to HomeKit through the Arlo app. I only see the 'Discovering your device. Please wait.' screen.
Steps taken:
Reboot Arlo Base Station and Cameras
Reboot home WiFi
Soft-reset iPhone
Uninstall & re-install Arlo appRestart Apple HomeKit Home Hubs (Apple TVs)
Confirm all Apple hardware is up-to-date with software
Confirm all Arlo hardware is up-to-date with software & firmware
Confirm all devices are on same WiFi network
Place cameras, base station, and iPhone within inches of each other
Leave iPhone on above 'Discovering your device...' screen for over 60 minutes
If someone could please assist me that would be great!
Steps taken:
Reboot home WiFi
Soft-reset iPhone
8 REPLIES 8
I'm getting the same thing but this has happened when NBN has been installed in my house did you have the same situation was it after NBN was installed
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Arlo cameras all worked fine through Apple HomeKit...but now are “Accessory Unavailability” after the latest Arlo App Update 2.15
Do you have a screenshot you can provide of the error message?
Using an iPhone X 13.4.1 and Arlo App: 2.15 147
The App just hangs as I try to re- add my Basestation.
What step within the Homekit app are you on?
Are you on the same wifi network as the base station?
A screenshot will help determine the issue.
I’m not in the Apple HomeKit app. In the Arlo App, where you set up HomeKit...the App just stalls. Yes...I’ve disabled Cell, and I’m on my home WiFi.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
