VMB4000 HomeKit Reset
Thank you
Hi. I have the same issue, with and endless spinning circle when trying to set up HomeKit. Can I get a reset token?
JoseCan,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Can you reset mine again? It's not working on my homekit again.
nammers,
Hi James, the HomeKit connection keeps crapping out on me. Its been 2 weeks since its last updated on HomeKit. I've removed the Arlo base station again from HomeKit; could you please reset the token again.
Also, any idea why it the connection works when you first do a token reset, but stops working later?
Regards,
Nam
nammers,
JamesC - I need a reset on my account as well, please. - ambroze72
Can’t connect to HomeKit.. Please reset the code for me too VMB4000r3: 4R058A7RA5E59
ambroze72, hoicju
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
