- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Trying to pair with homeassistant homekit - ne...
- 2
I'm trying to pair a vmb4540 base station with home assistant via homekit and it's asking for a home kit pairing code
My device does not have a homekit pairing code anywhere.
I've seen posts on here that I need to request a token reset. How do I go about doing that?
Thank you
Hi there at Arlo I need a reset token to pair VMB4000 to apple homekit please
Basta2024,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Do i get the pairing code if i do a tokenreset? in that case i would like to do that aswell.
I want to use it in my home assistant.
/Johan
No. You don't use the QR pairing code method.
Ok. how do i pair it with homeassistant then? using the hacs integration, or something else?
/JB
For homekit, if you see "Library" in your app menu, use the "setup an arlo device without a setup code" here:
If instead you see "Feed" and "Dashboard", then use
Arlo doesn't support homeassistant. There is a third party custom component called Aarlo, but I've never used it, and have no idea how well is works.
Hi,
Can you send an reset token to my base station please?
Regards,
Clement
How do I connect my Arlo device to Apple HomeKit?
- 2
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
