Token reset for Homekit
Hi,
After removing my base station from Homekit, it's no longer possible to re-add it. Could you please send a new token to my base station?
BR
Hi,
Could you please send a new token for this account as well?
johh, johh2
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Unfortunately it still doesn't work, despite following the instructions. I have two base stations connected to this account, did you send token reset requests to both of them?
johh2,
Sometimes there is a delay in the base receiving the reset. You may need to try again after waiting a couple hours.
Please let me know if you're still experiencing the issue after try again later today.
As it seems like the token has been ”consumed”, can you please send a new token reset request or give me another advice on how to continue?
johh2,
I sent another token reset request. Try again and let me know.
Now it worked perfectly, thank you!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
