Timelapse recording feature
  • 4 Replies
  • 11333 Views
  • 2 Likes
Senman
HI,
Is there a way to setup up a timelapse recording on the QPLus?  i am looking to record n view
every hour on the hour for 5 mins end of the day.
thanks
Right now the only way would be to locate or create an IFTTT recipe to do so.  I don't use IFTTT so can't comment if someone has already done so.  The Arlo configuration doesn't allow for this although you could manually do this if you subscribe to CVR (sounds like a PITA).
Adewale
Luminary
Luminary
I hope netgear will implement this feature across the range of cameras eventually to change the game and pull ahead of the competition
Reviewing each video recording is a put off
Senman
HI,
Yes, it is a simple feature but a well needed one.
On the long run it will store less data on the servers as well.
I hope the developers are seeing this posting:)
Cheers!!
Senman,
I encourage you to post this idea in the Arlo Idea Exchange or kudo existing topics there related to this.
Thank you for your contribution,
