HI,
Is there a way to setup up a timelapse recording on the QPLus? i am looking to record n view
every hour on the hour for 5 mins end of the day.
thanks
Right now the only way would be to locate or create an IFTTT recipe to do so. I don't use IFTTT so can't comment if someone has already done so. The Arlo configuration doesn't allow for this although you could manually do this if you subscribe to CVR (sounds like a PITA).
Reviewing each video recording is a put off
HI,
Yes, it is a simple feature but a well needed one.
On the long run it will store less data on the servers as well.
I hope the developers are seeing this posting:)
Cheers!!
Senman,
I encourage you to post this idea in the Arlo Idea Exchange or kudo existing topics there related to this.
Thank you for your contribution,
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
