Stringify replacement?
Hi
I use stringify in conjunction with IFTTT to turn my hue lights on and call my home phone when Arlo pro is triggered only at night. Any easy alternative to stringify now that they will be shutting down?
I suggest giving Sequematic a try. You can have any number of conditions, and also set up a sequence (similar to Stringify flow) or steps or actions to be performed.
It uses IFTTT to trigger your smart devices, so as long as your device works with IFTTT then it will work with Sequematic.
For the flow you've described, you could use the Arlo IFTTT applet as your trigger, then use Sequematic to check it is night time. From there, Sequematic could use IFTTT to trigger the phone call and turn on your hue lights.
Thanks to you both...I will look into these!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
