- English
- Arlo Forum Discussions
- Partner Integrations
- Some way of listening to the audio on a Google Hom...
Some way of listening to the audio on a Google Home speaker? I have an Arlo Q.
I have an Arlo Q is there some way of listening to the audio on a Google Home speaker?
Hi gordonz,
Could you clarify on your question? You can receive alerts and be able to view the live feed directly from your Google Assistant device with your Arlo Q camera. You can read more about it here: How do I connect my Arlo cameras to the Google Assistant app?
Thanks for your reply.
I can receive alerts on my Google Display OK (both audio and video) but I also have a JBL portable speaker and I want to receive audio from the ArloQ camera on the portable speaker.
When I ask the speaker to show or listen to the camera it says " it isn't available or cant be played right now".
I bought a speaker as I wanted to listen to the camera as I move about the property and all the displays I could find needed to be plugged into power.
AppleTV
31 -
Samsung SmartThings
82 -
Security System
