- English
- Arlo Forum Discussions
- Partner Integrations
- Re: SmartThings integration failing (motion events...
Best answers
Mine started working yesterday. I had to unlink and relink the Arlo account to Smartthings. I also had to redo the smartlighting automations in Smartthings.
Thank you for providing your feedback, I have notified the Development team & we are working on a release for early next week. I will be sure to update you as soon as I hear more!
Thank you for your patience while we worked to resolve this issue. The issue with the Arlo SmartThings integration and not receiving alerts should now be resolved. You do not need to relink your devices, you should now be receiving your automation alerts.
Alexa, Apple Homekit and Home Assistant (aarlo HACS component) work without problems with Arlo.
As for me.. I moved automations to Home Assistant
How will users be notified of a fix?
We’ll probably be notified by a mystical, magical unicorn ridden by a care bear who will deliver the message of a fix to us all personally…
IDK…been suffering through this nonsense since late last year. Who knows how or when they’ll fix the stuff that we all paid large sums of money for that seems to he all but useless now.
but I digress…
Same here, waiting for a solution!
Mine was working for a good 2 weeks, and now it it back to no motion events.. Very frustrating as I put all my automations back in place and deleted my Alexa routines.
I had it working well for a couple of weeks now it is not working again. How had can this be? Worked well for several years, Dec 23 stop working. Finally got it working again about 2 weeks ago and now broke again.
Same here!
SmartThings integration was the reason I selected Arlo.
Here’s the video:
Just saw this on Neighbors: https://neighbors.ring.com/n/ZGdeg48sWV
Samsung support get a 0/10 for support with this issue too.
Patience is running out
This is really getting old. I have so many Webcore pistons and Smartthings automations that rely on arlo motion detection outside. Nothing has been working for a while now. My pistons that operate my Arlo cameras and lights that don't rely on motion detection work fine.
What a pain in the , My 1st ticket was submitted in November. All my webcore functionality is useless, what other cameras work with Smarthings? I am ready to move on. I have been unlinking and relinking Smarthings every week. Sometimes it then works for part of day, sometimes a day, and until last week, It was working for almost three week straight! I not sure if they dont care or are incompetent
temporary using Alexa over smarting now
@ShayneS
I have the same issue and add and remove de camera from SmartThings did not help. Already restarted the SmartThings Hub, Arlo base and still the same. Anything else I can try?
I suspect it will require an update from Arlo, or for people to start using different cameras.
How are you all using Alexa. When working, I had notifications as a way to execute webcore pistons. So my front camera would notify whomever was home during the day, not when one of use was away but both when we were all away. Then another piston would execute after a set time at night, motion from any of the three cameras, would activate the siren for 10sec, turn on selective lights, speak a message trough Alexa with voice monkey, send push notifications and then turnoff the lights in a sequence over a period of time.
I removed Arlo from SmartThings, added Arlo Alexa skill and created the routines in Alexa
AppleTV
Samsung SmartThings
79 -
Security System
