  • 6 Replies
  • 4492 Views
AlmostTan
Hi,
So my Pro cameras are integrated and controlled by ST, which puts the cameras in a custom "mode".
When something is triggered, Arlo records a clip (15 seconds) and uploads it to the Netgear cloud.  I want this clip to be longer, but the slider doesn't allow me to.
Is there a way to make these clips longer?
6 REPLIES 6
I'm not conversant in ST so take this with a grain of salt.
If you're using a custom mode, why can't you simply adjust that mode/rule for longer recording?
AlmostTan
Thank you for the reply.
Unfortunately, it seems as though the custom mode enacted by SmartThings disables the recording length slider.
You can't create your own mode in Arlo and select it in ST?
AlmostTan
No, Arlo modes are not exposed to SmartThings.
I have escalated this topic for further investigation. I will post back when I receive an updated.
AlmostTan
Awesome,
Thanks James!
