RTSP link
Hi,
I have a security system in my home and it allows to add some security cameras, but they need to provide RTSP link.
I found a discussion about this, saying that, the arlo cameras uses it, but can't be used to integration with other systems because of their encrypted communication, but this thread was from 2015, I believe in 5 years there were a big evolution in arlo systems and technologies.
So, bottom line, I leave where the question, do Arlo cameras allow RTSP link to integrate with other systems?
And, if not, is there a way or a feature that allows that integration in someway?
Thank you
To the best of my knowledge, Arlo doesn't support RTSP in any way. You may be able to use a 3rd party capability such as IFTTT to perform this but have no idea if that would work.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
