New update removed Battery Icons on Android
  • 13 Replies
  • 10170 Views
  • 3 Likes
  • 9 In Conversation
sbtyper
Netgear, I know you are probably aware of this. Since installing the new update on Android I am no longer able to see the battery icons. I am able to seem them when I login via the website. I use rechargable batteries I am not sure if that is the reason why versus normal batteries. Please let us know how you are going to resolve this or when a new app update will be released to fix this.
Thanks.
13 REPLIES 13
sirmatt101
I use normal batteries and the icon is not there. Luckily I still have the previous app on another device so can still see the battery state there.
snip3rboy
Thanks.
Hi @sbtyper,
An update to the Android app will be available soon that will bring back the battery level. For now, you can use the browser app to get the battery level - https://arlo.netgear.com
snip3rboy
Thanks.
Hi @sbtyper,
An update to the Android app will be available very soon showing the battery level. For now, you can use the browser app to get the battery level https://arlo.netgear.com
enviousinc
Cameras just kill 8 batteries, a day ago was 3 bars with 1 camera and 2 barson the other. Two days later both completely out, dead camera. To the news from Arlo support false indicateion of battery level just continue to use until engineers fix the firmware issue will soon. They need to move fast lots people not happy of spending money on batteries.
Also, the most important is the motion on recording always behind like 1-2 seconds can't capture the front of the moving objects.
Recording starts too slow. ..
Subarusyd
Subarusyd
Hi netgear, same thing here too. Battery icon missing after update. Still no news on integration with IFTTT which is quite frustrating as you cannot automate arlo with other bome augomation products i invested in such as lifx,smartthings,amazon echo and nest protect.. was looking at purchasing more arlo cameras and also was looking at arloQ. No IFTTT Integration so will put on hold. Shame as it such a good product and it works!!!!
Subarusyd
Also recording is also still delayed by 1 or 2 secs as well..
Subarusyd
Hi Netgear, as soon i go to the browser arlo http link on my android phone, it is automatically redirecting me to a page saying download the relevant arlo app from the play store?!! It is not loading the login web page.
Subarusyd,
Do you have the Arlo mobile app downloaded and installed?
hokeysmoke
Virtuoso
Virtuoso
If you really want people to use the web portal from mobile devices, then you need to have your webmasters remove the automatic redirect.  Otherwise, just as others have reported, users will end up at a dead end with a page telling you to install an app.
That's one way to look at it.  Another is to use the (usual) selection from the browser menu to use the desktop version.  It's very similar to many other web sites that detect a mobile device and change the view which you may or may not want.
hokeysmoke
Virtuoso
Virtuoso
Most people are not aware of the existence of that option.  If you want to provide barriers to users, the best thing to do is to not explain how to do things to users trying to make your product work.
nickgtr35
fact of the matter is that Netgear should not have released the new updated app, the old one worked fine. Its obvious that they are trying to have one app to control the original Arlo product and the new Q product. They must have been under time pressure and have ended up releasing an unfinished app. Ridiculous for a company with such a high brand perception, they will end up destroying the brand if they do not get it sorted in a few days.
