Multiple arlo accounts on alexa skill
Carminehd,
No, only 1 Arlo account can be linked using the Arlo skill for Alexa.
Hello
If it is not possible to link 2 accounts on the skill, how is it possible to change the account formerly define ?
I have setup the skill with may "Accont01" and I would like to use now my "Account02"
When I disable the skill and re-enable it, I cannot change or find a way to setup another account
Thanks for your help
Luc
Hi @lzde01,
You can disable the skills and re-enable the skill through the Alexa app. You can read here on how to enable and disable skills: Enable Alexa Skills
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
