Hello!
I lost the ability to integrate my Arlo system with HomeKit. I have completely reset my Arlo and HomeKit systems, removed all devices, and re-added them to my Arlo app. Everything works fine if I use the Arlo app on it's own, but when I try to link the Arlo System with HomeKit through the app, it gets stuck on the Arlo App trying to Discover my system.
Any help would be greatly appreciated... Thank you! 🙂
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
MitchellNZ,
Hi James, thanks for the quick reply.
Unfortunately, this does not appear to have resolved the issue.
I have pulled the power for 5 minutes, then reconnected and followed the steps in the guide you linked. Its still getting stuck on "Discovering you device. Please wait." after attempting the HomeKit setup.
I have also recently update the Arlo iOS app to the latest version (3.6.3 (3404)) and ensured the device firmware is up to date. (version 1.17.1.2_3987_0e6c162).
Please let me know if there is anything I can try.
Thanks again!
Hi James,
Just following up again.
After waiting some more time, I gave it another go and its working once again!
Thanks for your help.
Piston38,
I believe I need a token reset request.
Idonlin,
Hi James,
I'm having the same issue. Could I please have a token reset sent to my base station?
Thanks,
Amy 🙂
amyglen, Idonlin, smurraybu
Can I have another token reset too, please?
@JG222 @amyglen
I have reset your HomeKit tokens. Please reboot your base station and test again
Hello,
I am having this same issue and have tried all the recommended steps can you try sending the token reset to mine as well?
Riclicious,
Hi James,
Can I have a token reset sent to my base station too?
Thanks!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
