Have a new 5S and have linked it with Google Home. I mostly access Google home from my IOS devices. In the Google home app the camera is shown and I can get a live view for a few seconds before the feed stops. My Pro 2s and essential stream ok. Trying to get a full screen view of the camera fails for all devices. All devices are at latest software/firmware.
Is there a problem with the interface between google home and arlo? Why does it only affect the 5S with dropped streaming? Why can't the other cameras be streamed in full screen mode?
This is a know symptom with Google integration and the Google team is aware and working towards a resolution, You can follow any updates on this here: https://issuetracker.google.com/issues/363903532
Hi @Jeff__h
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Relinked Arlo…rebooted entire network. Rebooted devices. Checked signal strengths. Check software and firmware versions. Accessing the cameras in the Arlo app and everything works fine…though the new app is not exciting 😝.
the camera shows in Google as does the others. In my favorites I have an essential, pro 2 and the 5s. They automatically start streaming when favorites is opened. All cameras start then the 5s stops streaming while the other two continue. On any camera if I select for full screen view, none of them steam which is a new problem.
Hope there is a fix as I rely a lot on Google for my home automation.
King regards.
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Express my appreciation to the development team
I am having a similar issue, I can see my camera live feed in the cameras tab of Google Home, but once I click on one to go full screen it just shows blank or says can't connect. I also cannot view on my Nest Hub devices. Any updates on this issue?
Developers are looking into the issue.
Can you re-link the google account and attempt the stream again? The team didn't see any live stream events on the diagnostic log. Also, can you provide the time-stamp when you try to stream and screenshots of what it looks like when it streams/stops?
Thank you, the info provided will help pinpoint the cause within the diagnostic logs/backend. Likely the team can not replicate the issue, so any information provided will help to get this resolved as soon as possible.
@ShayneS Any updates on this? I am still having the same issues as @Jeff__h . This has been going on for at least the last two months. It seems to be an issue with the way google is trying to access the live feed - I noticed with an indoor camera when initiating the live stream the privacy cover opens, but google is not able to pull the feed. This happens for all my cameras on wifi or connected through a hub. On Google Nest displays it try's to connect but eventually displays a screen saying Camera Feed is not available. In the Google Home app it displays the feed under favorites or in the Cameras section, but when trying to go to full screen it is black. Battery status is reported correctly.
Thanks for the follow up. The team is still investigating the root cause and I will be sure to keep this thread updated as I receive more information.
Thank you
Hi @ShayneS , got another question regarding Google home integration here . Could you help please? This is about lack of option for ARM HOME, under google home automation. thanks.
Alex
@Jeff__h wrote:
Tried to steam any camera on the Google home device at 9:15 AM. NO cameras will stream. Camera feed is not available is the message that is displayed.
interesting. I am able to stream any of my ultra 2 cameras (got a total of 3) to any of my two chromecasted TVs at home here.
Alex
Thank you for creating a new thread with that info. I have inquired with the team and I will add more info to that thread as soon as possible.
thanks. "as soon as possible" is important to both ARLO and its customers. If ARLO thinks the 3 modes a "good design", smooth automation is one of the best way for customers to embrace and love.
Apparently, nobody can even use automation to the minimal, in the new world.
Alex
Regardless of the devices you own, if you're using the latest version of the Google Home App on iOS, starting a stream from the "Devices" tab will not function correctly.
You can follow the progress on resolving this issue here: Google Issue Tracker
@HalinaK wrote:Regardless of the devices you own, if you're using the latest version of the Google Home App on iOS, starting a stream from the "Devices" tab will not function correctly.
another thank you to @HalinaK on this update 👍
As per message 19 above, I have been streaming fine to the chromecast of my TV --- likely because I was doing this google automation from my android device (vs google automation on iOS)
so @Jeff__h , for your failure case, were you trying to stream, using google automation installed on an iOS?
Alex
(ps: from message 1 above, @Jeff__h was exactly running this on iOS!)
All I did was add some of the linked cams to the favorites. When opening Google home it start with opening favorites and if there are cameras, it starts streaming the videos on all of them. Random results..all stream then stop..some stream then stop..but they all eventually stop.
your question on using automation is very vague and I’m unsure how automation would come into the picture.
@Jeff__h wrote:All I did was add some of the linked cams to the favorites. When opening Google home it start with opening favorites and if there are cameras, it starts streaming the videos on all of them. Random results..all stream then stop..some stream then stop..but they all eventually stop.
oh now I understand what you have been doing with google home and favorites .... since I never viewed that favorites page of Google Home before 😅
And yes I am seeing your "random" streaming issue too. (though I won't bother since I won't use this)
The automation I was talking about is, for example, using "hey google" to voice command google home to, say, stream a particular camera to, say, the chromecast of a TV. To me this has been working fine, though again I won't bother using such feature very often.
Alex
Alex
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
