Indoor systems
Someone is stealing from me inside of a house. I have staged with valuable antiques for sale. I want to set up a temporary indoor camera system that is wireless with 3 to 4 cameras. Can you suggest parts list that I need to order
Thanks for reaching out. There are several wireless options available to choose from. If you’d like to store recordings in the cloud, a secure subscription will be required once the trial period ends. Alternatively, you can use a compatible SmartHub or Base Station for local storage. To help you decide, you can compare available devices here: here
Let me know if you have any other questions 😊
What parts do i need to order for a wireless indoor system
You’re welcome to choose from any of the devices listed here, and this link provides a full comparison of our wireless camera options. If you can share a bit more about your specific needs or intended use, I’d be happy to recommend the best fit for you.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
