How well does tinycam work with Arlo
I am looking at switching from nest to arlo, solely for the tinycam integration so i can have a panel with both arlo and wyze cams on it. Anyone who uses tinycam with arlo attest to how well it works? Is its continued support expected?
I've installed it but don't really use it so can't really speak to overall use. However, there's another thread here from the author that you can read and see what others have said and questioned. From what I've seen, it works well and I would expect continued support.
tinyCam dev here. Both Arlo and Wyze cameras should work perfectly on the same screen in tinyCam app.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
