How do I fix the Alexa App showing I have two lights on, but it is wrong?
  • 1 Reply
  • 1187 Views
Truth2121
The Alexa says I have two lights though I don't have any on. The lights are for an Arlo Pro 3 Floodlight cam. It says two lights, but one is referring to the actual camera itself. Also, I have two other Arlo Pro 3 Floodlight cams, but they obviously are not showing up since they are working correctly.
JessicaP
Hi Truth2121,
You can try logging out and logging back on to the Alexa app to see if that updates the list and your camera list.
