Homekit token reset
  • 1 Reply
  • 1426 Views
AdHod
From searching for and reading other posts about adding device to homekit I believe  I also need a new token.
i have to Basestations, 1 is already added to Homekit and works fine, but the other one is stuck on “Discovering your device”.
Everything works as it should in the Arlo app.
Can I get a new token?
or is there an another way to solve this?
will a new token affect the already existing base stations connection?
thanks
BrookeN
If you can DM me the serial number of the basestation that is needing a token reset I can reset that for you. You send a dm by clicking on the envelope icon on the top right of the forum page.
