Homekit token reset
Hello. I need the homekit token reset on my arlo pro VMB4000r3
4058971A2348
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hi James, can you reach out to me about resetting my token for the base station? I recently moved and now I cannot connect the basest soon to HomeKit. Let me know what info you need from me. Thanks
ASSOA,
Hello,
could I also get reset. Not sure what has happened but cameras are offline in HomeKit and app proposes setup.
Device VMB4000r3
Serial number 4R058877A7D27
there really should be selfservice tool for this reset as this is at least 3rd time I need it.
also, any idea what happens after EOL (that I read somewhere in internet) for these resets ? Should not be needed as there is no firmwares, but…
Thanks & Best regards,
PJM
pjmakela,
Guten Tag
Dürfte ich sie um eine Freihaltung bitten?
Meine Arlo
VMB5000r4
besten dank
I need another reset token on my VMB4000 base station. Not sure why it keeps going out.
I need also a token please. Homekit not working
my basestation is vmb5000r6
I have reset your HomeKit tokens, Please reboot your Base Station or Smart Hub and try again.
Thank you
I would need a homekit token reset for my VMB4540 hub as well.
swagatjena,
I need another Token Reaet for my VMB4000. Already rebooted and Firmware is most current. Not sure why this goes out about every 3 months. Thanks for the help.
Knappster22,
vI've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
