Dear All,
kindly reset my device in order to integrate it with homekit.
thank you
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
Please reset the HomeKit Token for Guest House Base Station (VMB500 S/N ) thank you in advance
@JRoutWest I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
Worked perfectly, thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
