Hello,
I need a homekit token reset to my hub.
FW - 1.20.1.1_4167_eccc317
Model - VMB4000r3
Thanks,
Are you able to provide the serial number for your smarthub/base station?
Thank you,
Hi James
I also have the problem that i can't connect my vmb5000 with homekit. Can you reset my token?
Thank you!
Mine is solved, support could help me.
Yes. I can DM.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
