- English
- Arlo Forum Discussions
- Partner Integrations
- Re: HomeKit token reset needed – VMB4000R3
Hello,
My Arlo Base Station VMB4000R3 is unable to complete the HomeKit setup.
My Arlo Pro 2 is correctly paired with the VMB4000R3 and works normally in the Arlo app.
When I go to the HomeKit settings in the Arlo app, the setup gets stuck indefinitely on “Discovering your device. Please wait.”
Troubleshooting already completed:
- Base Station rebooted
- iPhone rebooted
- iPhone and Base Station are on the same local network
- Local Network and Home Data permissions are enabled for the Arlo app
- Base Station firmware is up to date
- The VMB4000R3 is not currently present under Hubs & Bridges in Apple Home
I have seen several reports on the Arlo Community where this exact issue with the VMB4000R3 was resolved by an Arlo moderator sending a HomeKit token reset to the Base Station.
Could an Arlo moderator please send a HomeKit token reset request to the VMB4000R3 associated with my account?
Thank you.
Alexis
I provided the How-to article with instructions on how to add your device to HomeKit here. Also, I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.
Thank you
Thank you
It works with the token’s reset !
Thank you.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
