My Arlo cameras have been working happily in HomeKit for some time now. Since upgrading to the latest iOS(15.0) the cameras disconnected and would not re-connect.
I see numerous posts here with JamesC sending new tokens to the base stations, but not sure if this is the issue this time.
Hoping some light can be shed on this one. Running latest Arlo app version on iOS and just get the white please wait page when I try and re-add (removed from HomeKit, power cycled etc)
I've sent a token reset request to your base station since you said you're trying to re-add your Base Station to HomeKit. Please reboot your base station (remove and reapply power) allow the base station to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
See if that works and let me know if the issue still persists.
Hi Jpegler,
Are you having issues when trying to view your cameras through the Arlo iOS app? What error are you seeing when trying to view your cameras through the Apple Home app?
Thanks for your reply. The Arlo iOS app has no issue displaying the cameras. HopeKit however became disconnected from the cameras after the update to iOS15 (cameras showing offline and hub was also offline).
I removed the hub from HomeKit and tried to re-add from the Arlo app, but it just sits there on the scanning page and does not progress.
So now my HomeKit does not have any Arlo cameras or hubs installed.
Thank you so much for your help, it added straight away.
How likely is this to happen in the future?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
