- English
- Arlo Forum Discussions
- Partner Integrations
- Re: HomeKit not working after iOS 15 update
Hey Effx,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hi KieranDubya,
And your feedback is noted and will be passed along to the development team.
Hi Effx,
Could you explain what exactly isn't working with your Arlo system and Apple HomeKit? Did you remove your system from Apple HomeKit? Are you seeing any error?
Is there a system wide solution to the current HomeKit Integration issues caused by iOS 15 upgrade? It appears that these are being resolved by Token resets being sent by a Community Moderator (JessicaP - BTW doing a fantastic job). But this seems to have a bit of a lag, and unfortunately calling support line is meaning no callback as requested.
I would like to resolve this issue. But would hope with what appears to be hundreds of shared experiences some sort of broader fix would have been issued after 3 weeks, plus issues existing in betas and RC iOS environments.
Regards, Kieran
Hey Effx,
Hi KieranDubya,
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
