  • 2866 Views
Davo1301
Google connects , then after a few seconds it says “something went wrong “ and does not connect . I have an iOS devise
JessicaP
Hi Davo1301,
Try removing your Arlo devices from Google Assistant and re-add it back on to see if that helps. You can read from this article: How do I connect my Arlo cameras to the Google Assistant app?
If you still have problems, contact the Support Team for them to help you further. You will find several options for contacting support in the provided link.
Davo1301
That did work at all I tried that many times and nothing
Davo1301
That didn’t work at all .. tried 100 times and nothing
