Google Next Hub Max integration is a real let down
  • 1 Reply
  • 1850 Views
Obfuskater
Is it just me that is really disappointed with the integration of this product with the Google Nest Hub Max?
I was expecting when someone rang the doorbell that a video window would pop up on the screen and I could tap it to answer the door and communicate with the person. While it is true it announces "There is someone at the door", this is a bit of a let down for a video door bell. I can tell there is someone at the door as the chime sounds. What I want to know is who is at the door with a video feed. Because it is a video doorbell. Not just a chime.
I can tap into the Home control section of Hub Max and select the Door video, but the average amount of time it takes to make a connection is 100 seconds (if it works at all). By then the person will have left.
Arlo + Hub Max really missed a trick with this integration.
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
