- English
- Arlo Forum Discussions
- Partner Integrations
- Google Next Hub Max integration is a real let down
Is it just me that is really disappointed with the integration of this product with the Google Nest Hub Max?
I was expecting when someone rang the doorbell that a video window would pop up on the screen and I could tap it to answer the door and communicate with the person. While it is true it announces "There is someone at the door", this is a bit of a let down for a video door bell. I can tell there is someone at the door as the chime sounds. What I want to know is who is at the door with a video feed. Because it is a video doorbell. Not just a chime.
I can tap into the Home control section of Hub Max and select the Door video, but the average amount of time it takes to make a connection is 100 seconds (if it works at all). By then the person will have left.
Arlo + Hub Max really missed a trick with this integration.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
