  • 239 Views
FrostyCan
I have been using a Google Home automation to take several steps, including arm an Arlo Pro SmartHub VMB4540r3.  That has worked fine for a couple of years, but in the last few weeks the rest of the routine works but the hub does not arm.  I have not changed anything in the automation.
To isolate the issue, I created a new routine with just the hub and the only step being to arm the hub.  That does not work.  No error is reported -- nothing appears to happen.
Using Google Assistant's voice command "hey Google, set my <hub name> to arm away mode" works, indicating that the sync between the two systems is not the issue.
Using the Arlo Secure app to arm the hub works.
What's the solution to having the Google automation arm the SmartHub again?
BrookeN
When you say you are "Using the Arlo Secure app to arm the hub works.”  can you explain more of what you mean?
Can you also send a screenshot of the following: Armed in Google Home while the cameras paired to it are Armed
FrostyCan
I mean that setting "Arm Away" in the the Arlo app works.
Just now I noticed that in the Google Home app each of the Arlo cameras show that they are offline, but I can click on them and get the live feed.  In the Arlo app, they all appear online.
Has something in the Google Home/Arlo integration broken in the last few weeks or is it just my setup?
BrookeN
Can I please get screenshots on how the you configure your Google Home app to Arm or Disarm the cameras?
