Garage door
Are their any garage door openers that work with this system?
I have tried door sensor which I guess is similar to your use case. The sensor is NOT an ARLO one, but something that is compatible with Google Home Automation (GHA). In my case, when door sensor is "open", I program GHA to trigger ARLO to switch to certain mode.
Aftermath: overall response from door open to ARLO mode change was too slow, I gave it up. But it is possible. And I guess your response time requirement with garage door less demanding than me opening the door (and expecting ARLO mode change immediately)
Alex
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
